Date:    5-3-2019
Number of Hours:    0.00
Brief Description:    Worked on avionics.
Removed ELT remote to bring home for testing with ELT. Revised mag switch wiring to stregthen, installed switches in panel. Revised avionics tray mounting to eliminate former barce to glare shield. Installed intercom in panel insert, added wiring connector, sorted out wires from avionics trays, installed in panel with black clecos. Installed transponder for test fit.
