Date:    4-15-2019
Number of Hours:    0.00
Brief Description:    Worked on second batch of parts at Milton's.
Inventoried parts at Milton's and classified as to what needs to be done on each. Jeanne worked on doors and I cleaned and test fit cowl latches. Tried to rivet clips but screwed up first rivet. Numbered latches and removed. Will paint separately and then reinstall at shop after painting. Sanded then primed and painted test section of door insides, looks good. Began masking off windows.inside and out.
