3-26-2019 |
0.00 |
Miscellaneous tasks. |
Gathered spray cans from garage and T hangar. Looked for 3/32 pop reivets, found just a few in the hangar. Painted the two wondsheild side strips, and the battery box cover. Sandblasted a few small internal parts, fairings, etc. Connected transponder coax, inserted grommet, routed across and up to radio stack area, re-secured with Adel clamps. Routed tailight and spare wire to tail, secured next to main battery wire. Installed coax on COM antenna, routed to radio stack, secured. Tried to connect diode and solenoid wire, not happy with condition of old solenoid connections, removed solenoid, took home and tested (good, draws one amp.) Sandbasted all old cowl latches, dissassembled the broken one. Recieved a reply to my question about latch parts on the C120 club website. Univair has all parts! Didn't expect that! |
