3-11-2019 |
0.00 |
Began paint prep at Milton's |
Moved cowling from T hangar to Milton's. Met with Jeanne and reviewed progress and tasks coming up. Decided against vinyl on panel. Decided to check possibility of using local (Glen's wife Dorie) to do the interior. Jeanne will contact her. Jeanne will continue to pursue source for shoulder belts. Worked with Jeanne to set up work area and start prepping parts for primer. Made a good first pass on HS and VS, they should be almost ready for primer. Took picture of little clips on aft side of HS, later looked them up in parts manual to see they are used for attaching fairings. Returned to airport and retrieved every part that we think will require exterior paint. Identified a couple that need dent removal, and a couple that need to be replaced. I will work on those after I finish the wiring project. Located yellow tool box with fabric tools and picked up from T hangar. |
