Date:    3-7-2019
Number of Hours:    0.00
Brief Description:    Worked on avionics wiring.
Discussed PTT buttons with Bill, made decision to locate them on the panel rather than the yokes. Ordered two PTT buttons.
Discussed primer for the fuselage and associated parts with Bill. Got info and asked Sandy to order a gallon. Took partial containers of catalyst and thinner from stock, since Chris says they should be used first before they age out.
Ordered and received LED lamp for Grimes light and brought home to test and adapt.
Added wires for PTT buttons to both mike jacks. Soldered up and tested all connections to the intercom DB-15 plug. (Found out later Bill has crimped-pin type in stock. Oh well.) Terminated speaker wire.
