6-22-2020 |
0.00 |
Prep for wing install. |
Got scat tubing and clamps and installed in both wings. Luckily, I have skinny arms. Attempted to make brackets for right-hand vent tube that came from eBay without them. Not much success. Can't rivet due to no clearance on inside. Emailed Todd Lifften to see if he has one with brackets. Shortened the AN3 bolts to same length as original part numbered special screw. Received last of the turnbuckle ends that we had ordered, replaced old one. Assembled and tightened bellcrank assemblies both sides. Placed in wings loosely awaiting Sam's help to get the pivot bolt and travel-limit pin installed. Double checked all wing attach hardware, found a couple of mistakes, corrected. Checked fit at all attach points, adjusted as necessary. Got the old interior from Cliff's hangar and spread out on our hangar floor. Called Mark at Airtex. He recommends buying 3M90 spray adhesive locally for headliner. |
