4-17-2018 |
0.00 |
Melted drain holes, fixed bump. |
Set up the little SCR box I got from Amazon to precisely control heat in iron. Set heat to just hot enough to melt not burn, made holes. Cut off rings of residue with razor blade. Repaired big bump. Measured open inspection hole and verified covers will fit. |
