3-17-2018 |
0.00 |
First sprayed coat Poly-Brush, tops. |
Looked at "nubs" with magnifying glass. They are little strings of the Poly-Brush. Book says this is due to too hot or too dry, Poly drying on way before landing. Nubs all over wings, both sides. Found best way to remove is scotchbrite, then iron with 225 heat. Did that, all sides. Added tapes to two spots where cross braces contact fabric. Flipped wings and prepped top surfaces. Turned off furnace and wet down the floor to increase humidity. Sprayed on a coat of Poly-Brush. Bill coached me in keeping the gun closer to the work. Much better result, altiough still some globs, Decided to quit for the day and order some BR-8600 Blush Retarder before proceeding. |
