12-6-2014 |
0.00 |
Continued covering the left wing. |
This week I pulled all the rivets in the top surface, applied the four coats of Poly to the tapes,and flipped the wing. On the bottom surface I drilled out a few missing and undersized holes, burned the rivet holes, inserted and pulled the rivets, Marked and pre-coated the tape location near the wingtip, an applied the first two tapes. |
