2-25-2012 |
2.00 |
Worked on corrosion on right wing. |
Drilled out and removed the smaller panel with the corrosion that resulted from the strap. This panel will have to be replaced for sure. But I am hopeful that the large panel may be able to be saved.. I sanded out the corrosion, which appears to not be very deep. It will be Bill's call. |
