Date:    9-22-2020
Number of Hours:    0.00
Brief Description:    Starter, antenna, brake leak, other...
Installed blade antenna on belly.
Put oil back in tank, checked for leaks at drain plug.
Installed starter, shortened and reinstalled starter wiring.
Adjusted carb heat control linkage to avoid rubbing on oil tank.
Looked for brake fluid leak left aide, tightened small screw where I think it was coming out.
Installed plugs in two extra firewall openings (with Sam.)
Installed new tach cable.
Received message from Rich Klein, he has a KT76A.
