9-21-2020 |
0.00 |
Starter, antenna, tach cable. |
Set up old salamander heater and tested. Set up CO detector in hangar. Received parts from A/S. Tag photos below. More photos on hard drive. Finished constructing headliner support brackets. Installed antenna on belly. Installed tach cable on engine end. Mounted starter on engine, discovered need to shorten cables due to redesigned starter. |
