Date:    9-14-2020
Number of Hours:    0.00
Brief Description:    Reinstalled and adjusted VR.
Located Cliff's box of generator and regulator parts, they turned out to be of the 35-amp variety. Installed old regulator in airplane without cover. Checked wiring connections in airplane. Started engine and observed a high voltage and charging rate. Adjusted voltage regulator with multiple trial and error runs to obtain close to 13.8 volts. Same routine with current regulator to achieve 12-amp max current. Buttoned up for test flight tomorrow.
Spoke with Bill and Chris about locating a KT76A transponder for substitution testing.
