7-6-2020 |
0.00 |
Removed winshield, worked in that area. |
Removed windshield. Reworked the two wing root covers so they fit and made hole for right hand vent tube. Painted with interior paint. Determined that wiring coming up from behind the panel must go around the outside of the doorposts. That required disconnecting the previously installed strobe and com antenna wires. Shortened the aluminum pitot tubing in the wing root to allow room enough for the tubing going down into the ASI to make a proper bend. Made a hole and inserted a grommet in the right-hand fuselage skin for wiring to pass through. Used existing large hole on left side and install edge protection strips. Located and installed ELT remote control telephone-type wire. |
