5-30-2020 |
0.00 |
Workbench cleanup and various small tasks. |
Sorted out and reorganized remainng parts and pieces that came from the shelf unit, and cleaned up bench. Tried generator nut Glenn left for me, found one slightly better with other old stuff, installed wires on generator, used lock washer and a lttle Loctite on field terminal. Cleaned and marked magneto caps, checked high tension wire routing and lengths. Experimented with assembly of wires at mag ends. Looked (unsuccessfully) to find info on use of the little ferrules. Recieved diagram and dimensions for strut bushing from Randy Thompson. Installed LED bulbs, tested with battery. Figured out (I think) how the fwd rod ends and bushing |
