5-20-2020 |
0.00 |
FWF wiring +... |
Sam adjusted trim tab travel to specs. I installed data plate and mag compass on dash. I tested primer with 100LL and it seems to work without leaking. I selected the larger start button and installed it in the panel. Located correct nut and secured oil pressure gauge to floating panel. I routed, connected, and secured remaining FWF wiring. In attempting to install filter capacitor I loosened one of the long generator bolts and was not able to rethread it. Generator will have to come back out to install filter, hook up magneto P leads, Also, we are missing one of the special nuts for the connecting posts. |
