3-17-2013 |
7.50 |
Rudder Pedal Assembly - Pt 3 |
Another long day, but I got everything but the rudder pedal straps assembled and welded. Apprently I was pretty intent on getting this done because I didn't take that many pictures. I did get a few at the beginning making the rudder cable arms, and a final one. Oh well. I used full size copies of the arms pasted to the correct thickness sheet using rubber cement. I drilled a hole on the weirdo inside corner to make sure it has a radius, and then just cut them out on the band saw. When bending them, remember that there is a LEFT and a RIGHT, and they are different. |
