7-22-2017 |
3.00 |
Aileron Hinge Bracket |
I really took my time with this as there was no way to secure the bracket(s) to the wing. I was also very sensitive that it is a QB wing and the first drilling that I would be doing, that if I got wrong, would end in tears. I used the upper hole to drill first. I aligned and then secured this with a nut and bolt. I then drill the lower hole. Seemed to worked OK. |
