Date:    7-22-2017
Number of Hours:    1.00
Brief Description:    SB 16-03-28: Cracking of wing aft spar web at the
This Service Bulletin is required due to: Cracking of wing aft spar web at the inboard aileron hinge bracket attach rivets.
For RV-3/3A/3B, 4, 7/7A, 8/8A, 9/9A aircraft: being installed during build.
I used this hour to understand wat needs to be done.
You can see in Image 3, the Aileron Attach Doublers in place.
Next to prepare the Doublers for priming.
