12-10-2016 |
1.50 |
Install Aileron Brackets to Rear Spar |
Install W-413L&R and W-414L&R aileron brackets on rear spar. See Builder’s Manual section INSTALLING THE AILERON BRACKETS in the RIVETING THE WING SKIN Section and DWG 13A. Assemble the W-413 and W-414 Aileron bracket assemblies as shown on DWG 10A. Install them on the rear spar by lining up the matched holes, drilling, deburring, and riveting. ******************************************************************************************************************** This step is pretty straigh forward. I set up the parts and match drilled. |
