Date:    12-10-2016
Number of Hours:    2.00
Brief Description:    Fabricating the W-716
Make the W-818 and W-716 pushrods. See Builder’s Manual section ATTACHING AILERONS TO THE WING and DWG 15A.
Assemble the W-716 and W-818 pushrods as shown in DWG 15A. Prime both pushrods inside and out. Cover the inside by pouring a small quantity of primer inside the rod and slowly swirling it around or by spraying into each end.
I prepares the outside of the aluminium tube in the usual fashion for priming and primed accordingly. For the inside of the tube, I sprayed a quantity of the primer into the tube. I was not happy wiht the coverage and so sealed one end and opured a quantity of primer into the tube and slowly swirled around according to the instructions.
