Date:    10-11-2014
Number of Hours:    1.00
Brief Description:    RV 12 personal hangar
Shelter Station hangar used for our skyfox prior to the RV12 being cmpleted.
The structure is a modified LEGrand model "Shelter Station" product.
- The Structure has the following modifications to make it suitable for use here in the North West.
- A 50 x 25mm RHS doubler fame inside of each of the bows
- Utilises the earth augers supplied with the shelter as well as dyna bolted to a concrete slab that was 3/4 of the length of the shed.
- 1/8" cable bracing in the wall bays and the roof bays
- Aircell insulation lined to reduce the heat inside the shelter to ambient temp
- 5 X 750Kg Ratchet strap bracing across each end to give extra support as well as support for the end flaps (Doors)
