4-11-2016 |
1.25 |
Control Column Mounts and Ribs Removed! |
Got the Control Column Drilled to the spare plate and riveted in place. Also re-inserted the faux wood spare after removing the nutplates from the previous builder for the two removable ribs. Spar slid right in and bolted up. I have some rib trimming that will need to be done for the control column freedom of movement! |
