ROBERT'S WEB SITE
Date:  6-4-2012
Number of Hours:  1.00
Brief Description:  Rear Spar work
For the right side rear spar, I match drilled the doublers for the aileron brackets. I then traced the cutout for the aileron push rod and went after it with the step drill bit in the drill press, then a file, and finally with the 1” scotch bright wheel. It seemed to turn out pretty well.
Match drilling
Match drilling
Aileron Push rod hole
