-Riveted HS 404 & 405 on the front spar assemble -Cleaned up the right side HS skin with the scotch brite pad and Dawn detergent -Dimpled RH HS skin. Learned to dimple skins the correct way with the DRDT dimpler. Male die on top. Access is better to more holes, and you don’t scratch the skin up like on mine…
