ROBERT'S WEB SITE
RV7A
Fuselage - Forward F
2-23-2022
Center Section prep
Before adding the forward wing bulkhead I bolted on the seat ribs and control column bearings. 25 in-pound torque and torque seal. I also inserted the spar spacers and a 14 in drift pins to hold then.
Torque seat rib bolts
Control column bearing bolted in
Torque stripe applied
RV7A Home
1152
Ailerons
Baggage Compartmet
Elevator
25
Firewall
Flaps
Flying
Fuel Tanks
89
211
67
127
Fuselage - Mid Fusel
Fuselage Bulkheads
Fuselge - Aft Fusela
Horizontal Stab
Post Flip Fuselage
Rudder/Brake Assembl
Shop
Supplies
Training
Trim Tab
Vertical Stab
Wing Leading Edges
Wing Spars
