So, back a ways I put in both the Pitch and Roll Servo installation kits from Dynon. Since then I've decided to use the Gamin Autopilot servos. The Garmin support folks will say you can use other mounting hardware but say that it is up to you to make it work. So I've decided to use the Garmin installation kits while the fuselage is still open.
The Garmin pitch kit is on order. I should get it next week.
