Before I start riveting all of this back together I want to make sure all the CT (close tolerance) bolts will readily fit through each section of the wing box bulkhead. Tonight I was working on the aft end of the bulkhead. Again, the lateral bulkhead alighnment in the assembly seems to be problem. A sanding wheel is what I am using to clean up the sheet metal part and not touching the big thick bar.
