ROBERT'S WEB SITE
Date:  11-12-2016
Number of Hours:  1.50
Brief Description:  Longerons 10 - the big twist
This wasn't too hard. I clamped up each longeron individually to crank in the twist. The protractor app worked well for this. First I calibrated the protractor at the vise to zero degrees. Then with the crescant wrenchs it took greater then a 90 degree twist to get the 17 degrees required.
Calibrate protractor app at the vise
Twist with two wrenchs
Close enough
Close enough
