Brief Description: Wing Center Section 8 - Cover Support Ribs
For the F704M stiffeners, I fished out the angle and cut the stiffeners to length on the band saw. Finished to the cut line and drew a centerline on the back side to to guide alignment and clamping to the bulkhead. Then I drilled out each hole #30.
