I started out by drilling out and replacing the two bent over shop heads from the last session. No problems with these.
The FL706A and FL706B are joined with some standard solid rivets. These were easily done with the squeezer.
Next the outboard end rib was riveted with the squeezer. I could get all but the most aft rivet with the no-hole yoke. I used a pulled rivet here like on the right flap.
Lastly the bottom skin/spar/flap hinge line was riveted with the squeezer working from the inside out. Done with the flaps.
