I haven't trimmed the J stringers (F-786A L/R) to length yet. Drawing 18 says 50 3/16" overall length and shows aft end trim dimensions. There is also a note to trim to fit. Seems like the aft skins will really set the overall lengths. Not sure what the forward end trim should be.
I put the aft bulkhead in on the wrong side of the Aft Deck. I need to pull that out and reverse it. I should probably go ahead and rivet it in.
The plans call out fitting, drilling, and riveting in the F-656 L/R gusset plates to the F-706 & F-707 bulkheads prior to fitting the skins. But the bulkheads above the longerons isn't exactly fixed. You can move them around and it seems (again) that the skins are going to set the bulkhead locations and hence the F-656 gussets.
