Brief Description: Four holes I should have drilled earlier
When I removed the side skins for prep and prime, I noticed that the F-704 bulkhead needed to be drilled to the longeron. After I got through prepping both skins and priming one, I finaly got around to drilling the four required holes on Christmas eve. Since the F-704 would just flop around without the side skins on, I cleacoed the skins back on first.
F-704 bulkhead to longeron detail
Quick two holes per side through longeron into the 704 bulkhead
