ROBERT'S WEB SITE
RV7A
Rudder Assembly installation 1
Marked the most forward pedal block position (3" per drawing) to start. Then removed the F719R angle to drill using the side block mounting holes.
I drilled two additional locations 1 1/16" back from the forward posisiton (marked "M" and "F" in photo 3).
Transferred the block positions to F719L and likewise drilled the mounting holes.
Note, the mounting blocks have specific orientation to fit the fuselage that I did not pick up - see later log entry.
Mark 3" back for most forward pedal length
Clamp and drill
Transfer side block marks to F719L
RV7A Home
1152
Ailerons
Baggage Compartmet
Elevator
25
Firewall
Flaps
Flying
Fuel Tanks
89
211
Fuselage - Forward F
67
127
Fuselage - Mid Fusel
Fuselage Bulkheads
Fuselge - Aft Fusela
Horizontal Stab
Post Flip Fuselage
Rudder/Brake Assembl
Shop
Supplies
Training
Trim Tab
Vertical Stab
Wing Leading Edges
Wing Spars
