Right side now. I tried to incorporate everything I learned for doing the left side but it took several trys to do that. I ended up ruining two of the 796 angles in the process. First one was when the angle shifted alignment when I was drilling. I am not exactly following the plans here, just stacking up the parts, clamping, and then drilling. The first miss was from not clamping it well enough. I ruined the second one by making the part too short - this comprimized the edge margin on the lower hole that gets AN 3/16" bolt. Third try tonight worked...
