Brief Description: Side skins prep and initial fitting 1
Standard prep on the wing skin before I put it on.
Getting the clecos in was not difficult. I started with the seat back bulkhead, then clecoes in the 705 bulkhead and finally in the aft bulkhead. It took some effort to these last clecos in by adjusting the aft fuselage hieght.
I did notice that I had put in two rivets that I shouldn’t have where the side skin bend is attached (aft fuselage). I’ll have to drill those out.
