Brief Description: F-623 Corner Ribs 3 and drilling ribs to bulkheads
After creating one set of fore and aft straps, it was easy to create the other set by tracing the first set. I repeated the same process on the other side.
Next I drilled the rib holes through the forward bulkhead and counter sunk the top holes.
Joggle in the aft strap
Drilling the ribs through the forward bulkhead
Countersink the bulkhead holes for the top rib rivet
