Brief Description: Wing Center Section 11 - wrap up
I riveted on the cover support brackets and backing angles. In a moment of inattention I let the rivet gun bounce and put a big smilely on the head. No issues drilling it out and replacing. I installed, torqued, and marked with torque seal the bolts through the larger cover support brackets. Lastly, I sanded down a flat spot on the four outer bushings to get them to fit.
