You start with riveting the FL 706B to the inboard rib and the FL706A to the front spar. Easy work with the squeezer except when you screw it up and have to drill out all the rivets so you can put the part on the right side of the spar (duh!). Drilling out the rivets and replacing them was straightforward and re-riveting was no problem.
