Brief Description: Right Wing Aileron Hinge Brackets, Gap Seal, and F
I screwed up the priming job from yesterday somehow, so today I redid it. The primer is lifting in some areas. It is easy to fix with a quick scuff up and wipe down with lacquer thinner. In between coats I kept going with drilling out and replacing bad rivets in the top skin aft edge. Two needed oops rivets. I think this wraps up all the bad rivets in the top skins (finally!).
