Brief Description: Aileron gap seal and Flap brace prep – Left wing
Next is the aileron gap seal and flap brace. I got both parts out, stripped off the plastic and worked all the edges with the file, debur tool, sandpaper, and scotchbrite wheel. The flap brace requires trimming an edge off to fit the rear spar. I used the band saw to make this cut. Finally, I cleaned up the parts and primed them.
