ROBERT'S WEB SITE
RV7A
Pitot Mast mount 2
The angle is then clamped in place and the rib match drilled and the other flange leg match drilled through the skin.
Next the mast hole is created with a drill/step drill/hacksaw blade/file/sandpaper.
Finally, debur and dimple.
Side angle in place - hole drilled
Through drilling angle to rib
Cutting out the mast hole in the skin
RV7A Home
1152
Ailerons
Baggage Compartmet
Elevator
25
Firewall
Flaps
Flying
Fuel Tanks
89
211
Fuselage - Forward F
67
127
Fuselage - Mid Fusel
Fuselage Bulkheads
Fuselge - Aft Fusela
Horizontal Stab
Post Flip Fuselage
Rudder/Brake Assembl
Shop
Supplies
Training
Trim Tab
Vertical Stab
Wing Leading Edges
Wing Spars
