Brief Description: Riveting Right Top Main Skins 1
I started by drilling out a couple bad rivets that attach the ribs to main spar flange under the fuel tank. These are not called out on the plans or the construction manual, but it is pretty obvious that they need rivets. I also riveted the rest of these on the upper side.
I then 100% clecoed the upper main skins on after leveling up the wing structure.
Pauline then came down and was my bucking partner on the inboard skin interior rib riveting. She did a great job and we settled into a rhythm pretty quick.
