I leveled up the left wing assembly again with the bottle jack and fishing line.
I clecoed on both skins and checked the countersink depth on the spar flange and the fit up at the scarf joint. About a third of the countersinks are not deep enough and these effected the scarf joint as well so I couldn’t tell if that was good. I pulled the skins and redid all the marked countersinks and then put the skins back on.
