ROBERT'S WEB SITE
RV7A
Riveting on the Rear Spar
-Started riveting around the edges. Same technique as the HS. Set the rivets with the rivet gun and then finish with the squeezer.
-Had to drill out a couple and replace.
Rear spar
RV7A Home
1152
Ailerons
Baggage Compartmet
Elevator
25
Firewall
Flaps
Flying
Fuel Tanks
89
211
Fuselage - Forward F
67
127
Fuselage - Mid Fusel
Fuselage Bulkheads
Fuselge - Aft Fusela
Horizontal Stab
Post Flip Fuselage
Rudder/Brake Assembl
Shop
Supplies
Training
Trim Tab
Vertical Stab
Wing Leading Edges
Wing Spars
