ROBERT'S WEB SITE
Date: 9-6-2011
Number of Hours: 6.00
Brief Description: Rudder Assembly and drilling
I took the day off today from work (day after labor day) and put in a pretty much a full day. Clecoed the skins on to the Rudder skeleton. Final drilled skin/ribs/spar/trailing edge on both sides. I’ve put off back riveting the stiffeners to the skins as the plans call out. I was leaning this way in any case to save some wear and tear on the primer on the inside of the skins. When I saw the same approach on another (repeat) builder’s site I figured it was OK. -Trimmed rudder brace, clecoed it in, and final drilled -Fabricated lower fairing attach strips, clecoed and final drilled -Started the disassembly of the rudder. Deburring, edge finishing, and dimpling as parts were removed Lower fairing attach strips Rudder horn, brace, shim, re-enforcing plate Lower rib
It was bound to happen sooner or later. While pneumatically dimpling, I punched a new hole in the rib flange. This created an oblong hole in the flange. A quick note to Van’s tech support with this picture and I got the reply I was hoping for. The lower fairing attach strip acts as a doubler in this case and no part replacement is required. Build on!
I used my new close quarters dimpling tool on the three most aft holes. The thin female dimple die and the male die in the rivet gun makes a pretty good dimple. Got this from Cleveland Tools. EAA has a nice video on how this works. -Trailing edge strip removed – haven’t counter sunk it yet. I need to practice on the Van’s wing section training kit first. I think it is the same stock material, so I can use that to get the countersink set up right. -Right side rudder skin -Called it a night. William needed a little help getting the bed frame pieces collected. He moves into his off campus housing tomorrow.
Skins on
drilling the lower fairing attach strip
Uh-oh
