Brief Description: Riveting stiffeners on front spar
-Riveted together the HS710/714 stiffeners to the HS front spar (HS703). One bad one that I drilled out and replaced. Had some questions about which side to put the shop head/manufactured head when riveting. Some later research on other builders sites indicate that generally it doesn’t matter but put the manufactured head on the thin material side if possible.
