Dave Yost RV-4
Date:  2-2-2013
Number of Hours:  1.00
Manual Reference:  Drawing 6a
Brief Description:  Prepairing the elevator bearing bracket
The elevator breaing bracket must sit flat on T.E. Spar surface. One side is drilled, the other must be match drilled. Left as much powder coat as I could while surfacing the brackets to get them to sit flat. I clamped them together on a mechinest granet to ensure the two flages where flush,then match drilled.
I will prime them to match the rest of the parts later.
Too Much Powder Coat
Clamp on flat surface
Match drill
Match drill
