Finished up the rear blade support, flattened the ends of the tubes and drilled holes to match the holes in the frame tabs. Applied 3M paint protection tape to the frame tubes and tabs where the blade support will attach. I just need to find some thin foam to line the inside of the cradle and this support is done.
