Mikes Helicycle
Helicycle
Main Rotor
4-15-2012
Blade supports
Went back out after supper and mostly finished the rear blade support.
Riveted the two angle pieces to the bottom of the cradle.
Bolted on the channel piece.
Cut two 35" pieces of conduit, drilled and bolted the conduit to the cradle.
All that remains is flattening the bottom end of the tubes and drilling the holes so it can be bolted to the frame.
Counter sinking the hard way
Brackets riveted to blade cradle
Alomost ready to hold a blade
Helicycle Home
Cabin
Drivetrain
Frame
Fuel system
Instrumentation
Main Rotor
Main Rotor
Paperwork
Tail
Tail Rotor
